Jump to content
Correction of identical vertices
From LDraw.org Wiki
Identical vertices can occur by using applications in part authoring process or by error if typing by hand. Possibilities for correction:
  • Linetype 2: If vertices 1 and 2 are identical - just delete that line
  • Linetype 3: If vertices 1 and 2 or 1 and 3 are identical - just delete that line
  • Linetype 4: If vertices 1 and 2 identical but 3 and 4 not identical and 1 and 3 not identical - change to triangle (linetype 3). If the quad can not be transformed to a valid triangle (there are 4 possible ways!) then delete that line
  • Linetype 5: If vertices 1 and 2 identical then delete that line
All other identical vertices should be inspected by human as it might be only an error in defining the vertices.
Below please find the content of a test file.
0 Identical Vertices Testfile
0 Name: identical-test.dat
0 !LICENSE Redistributable under CCAL version 2.0 : see CAreadme.txt
0 !HELP This file should help to detect errors in software that corrects identical vertices
0 !HELP errors.
0 BFC NOCERTIFY
0 !CATEGORY Animal
2 2 10 0 0 -10 0 0
0 // the above line should stay.
0 // the following line should be deleted.
2 4 10 0 0 10 0 0
0 // the following line should stay.
3 2 10 0 0 0 0 10 20 0 0
3 4 10 0 0 10 0 0 20 0 0
4 2 10 0 0 10 0 10 -10 0 10 -10 0 0
0 // the following line should be transformed to triangle.
4 4 10 0 0 10 0 10 -10 0 10 10 0 0
5 2 10 0 0 -10 0 0 0 0 10 0 0 -10
5 4 10 0 0 10 0 0 0 0 10 0 0 -10
5 2 10 0 0 -10 0 0 10 0 0 0 0 -10
--Mikeheide 10:03, 24 June 2011 (EDT)
