LDInspector - Comparing Part Lists
Jump to navigation
Jump to search
This page shows how to compare 1 or more part lists or models using LDInspector.
Select first part list and do a right click on "CS" in the table header. In the appearing popup menu select "Copy row".
This will result in a copy of CS named C1.
Select the second part list, also right click on "CS" and select "Copy row".
Finally select the part list you want to compare with.
Changing "Show all" to "Show diff" will only show items that differ - here the Rebrickable PBG in C1 has several differences to Bricklink in C2, which is almost the same as the selected model in CS except for the "Tyre 6/50" color.
Skipping the Rebrickable list and thereby comparing the model with the Bricklink list, only the "Tyre 6/50" remains as difference.
